For those with Wet Brakes....
   / For those with Wet Brakes.... #1
Scotty Dive
Platinum Member
Ct
Yanmar 2020D
I replaced the right side brake boot awhile back because it leaked a bit. With the new boot it does the same. Is there a seal that is easy to get at to fix this? I can also live with the small leak, but wanted to ask if letting it go is going to cause some issue in the future???
   / For those with Wet Brakes.... #2
The boot is the seal, no other seal involved. Hard for me to understand why your new boot would leak. At what point does it leak?
I thought the boot was the seal as well. There is a shaft that runs through the boot and it leaks there at the hose clamp. its just a drip or two but definitely leaving a mark on the ground/rocks.
   / For those with Wet Brakes.... #4
Could your vent tube behind the seat be plugged and getting pressured up? Is the shaft fairly clean & not rusty or scored?
   / For those with Wet Brakes.... #5
No experience with wet brakes but that plugged vent is usually the cause of the shifter boot leaking.
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2009 FREIGHTLINER CASCADIA SLEEPER (A51222)
2009 FREIGHTLINER...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
