Oil & Fuel ? for those that added oil pressure gauge
   / ? for those that added oil pressure gauge
turnerbend, all I did was to pull a wire piggyback straight from the fuse block and used the gauge bracket mounting screw for the ground. If you plan to drill a hole for the gauge most any bolt or screw will give you a good ground, just get down to bare metal. Of course I say get to bare metal but my ground was simply slipped under a sheet metal scew and was a good enough ground. Nice old building in your profile. Oh for the light just pull off the hot side of the voltmeter. Make sure the terminal you come off at the fuse block is not constant hot, must be controlled by switch. If the gauge light works you have a good ground.
SOMERO S-222 LASER SCREED (A52707)
SOMERO S-222 LASER...
2021 JOHN DEERE 7R230 LOT NUMBER 204 (A53084)
2021 JOHN DEERE...
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
2014 Ford Fusion SE Sedan (A53424)
2014 Ford Fusion...
2015 FREIGHTLINER 122SD TANDEM AXLE DAY CAB (A56138)
2015 FREIGHTLINER...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
