Footbridge safety ideas needed
   / Footbridge safety ideas needed #1
lhfarm
Central Indiana
NH TC40DA
We have walking trails around the property and I need to improve safety in winter weather. The bridges are small, 4' x 8', made with treated lumber. My wife has asked for a handrail and that seems reasonable. I've been hiking on the AT this summer and noticed that may of their bridges now have a metal meshing on the boards. That seems like a good idea to me. Not sure what they are using. Would appreciate any ideas/suggestions.
Thanks,
   / Footbridge safety ideas needed #2
Not sure about the metal mesh but I just used an old roll of roofing material on our walking bridge. It adds a little traction.....especially when it get a little icy. It lasts several years and is cheap to do. Good luck!
   / Footbridge safety ideas needed #3
Stucco lath? I've seen that used on wooden ramps. I'll be adding it to the ramp to the manure pit.
   / Footbridge safety ideas needed #5
Just chicken wire attached to the bridge would work. Definitely need a handrail. Someone near here had a concrete bridge across a stream that he had to cross to get his mail every day. He was reading his mail one day and walked off the bridge. Did rather extensive damage to himself.
Ralph
   / Footbridge safety ideas needed #6
At our quarries and sand and gravel operations, we use a few different types of metal for elevated walkways and platforms. Flat steel grate works well on horizontal as well as flat areas, but can be expensive. A better alternative from a cost standpoint is an expanded metal that we get that has a little twist in it to allow a sharp side to point up for traction. Not sure what the steel yards call it, but if you describe it, they'll know exactly what you need. If you ask pretty they may even cut it to size for you. Good luck!
Sent from my LGL35G using TractorByNet
   / Footbridge safety ideas needed #7
P.S. The expanded metal looks just like the stucco metal sheets, just substantially bigger and more durable.
   / Footbridge safety ideas needed #8
Of the most easily available material, I think I would choose 1/2 inch hardware cloth.
Bruce
   / Footbridge safety ideas needed #9
Why not stain with the traction stuff added to it.
   / Footbridge safety ideas needed #10
2014 Ford Escape (A50323)
2014 Ford Escape...
(6) Goodyear 8.25 R20 Tires (A51573)
(6) Goodyear 8.25...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A53472)
John Deere 6105E...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
2020 INTERNATIONAL MV607 24FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
JLG 1255 Telehandler (A53472)
JLG 1255...
