Foam insulation - Making cabin from prebuilt shed
   / Foam insulation - Making cabin from prebuilt shed #31
I bought a diy kit, from foam it green. They supplied a bunch of tips and tyvek suite (it bunched up got some foam on me and tore hair off my arm). What I did was prep the entire area, drop cloths all over taped and stapled where I wanted it, ladders in place etc. That way when I sprayed I kept going. If you stop for 60 seconds then that tip is ruined and you replace it with another. It was very easy to use, like a paint gun.
It came in two lp grill tank sized tanks. The company even emails you when the temperature is right in your area.
Forgeblast, I have looked at them for a small area. How was the yield? They say something like 600 sq ft at 1 in (or maybe it was 2)
   / Foam insulation - Making cabin from prebuilt shed #32
Honestly it was almost 8 years ago(I cant remember the actual yield) it covered everything i needed it to, I remember being impressed with what I got. I actually did a bunch in my basement and in my attic.
PAIR OF UNUSED 60" HANG ON FORKS (A54757)
PAIR OF UNUSED 60"...
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
John Dozer JD650 (A51691)
John Dozer JD650...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
