Foam filled vs Slime need feedback
   / Foam filled vs Slime need feedback #11
I've used slime for more than 4 years on my thorny property and have had one flat since I put it in. It is removable, and you can change tire preasures all you want. It was $7 a quart and it took 6 quarts for all four tires on my 2710. For the price of foaming the tires I didn't even consider it.
If your property is too harsh on the tires you can remove the slime and get the tires foamed. But if you foam them its forever.
   / Foam filled vs Slime need feedback #12
I had Arnco Superflex Softfill put in my tires. It's more flexible than regular foam. The dealer showed me examples of both materials. It's in the $1.25/lb. range in this area.
I don't notice much difference in the ride over air and I mow an old pasture w/ruts,bumps. The additional weight in the rear is nice when I use the FEL. I'm a happy camper.
Dave...
   / Foam filled vs Slime need feedback #13
Slime!
I put a quart in each front and about a quart and a half in each rear.
I ran over a sharp piece of metal and cut the sidewall on a rear.
Slime even stopped that!!
2019 Genie GS-3232 32ft Electric Scissor Lift (A53421)
2019 Genie GS-3232...
VENTRY FAN / BRUSH BURNING SKID (A55745)
VENTRY FAN / BRUSH...
Estate Equipment Auction 9/27/2025
Estate Equipment...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
2012 KENWORTH T660 ROAD TRACTOR (A57192)
2012 KENWORTH T660...
