Tires Foam filled tires...should I?
   / Foam filled tires...should I? #11
Never say never. Thats when my ol bud Mr. Murphy sneaks up and bites you.
Thanks for answering my question. This summer I've done a lot of different work at a lot of different locations. Sometimes I vary my air pressure a couple of times a week, for optimum traction.
   / Foam filled tires...should I? #12
Yes, cost is a disadvantage. I use Calcium Chloride in the
rear tires, better ballast and flexibility to change pressure.
But the front tires are foam filled, for puncture resistance
in the woods, and to support the weight of a loaded FEL.
Do this when you're mounting new tires, since the foam will
cost you $70 or more per tire and you'll have to cut the tire
off the rim when you're ready to change again. Also my
supplier often makes me wait several days, as it is more
cost effective for him to do a batch of several tires rather
than 2 small tires. Other than that, it's great stuff.
Well, after much thought, I ended up going with R4s, and buying a b2910 Kubota, so I don't feel the worry about flats that I had with the bar/turf combo that it looked like I might get on a 2410.
So I have decided not to foam fill the tires, and not even to fill them at all on purchase. But I may go to a place that is going out of business and buy a bunch of windshield washer fluid, at 80 cents per gallon, and fill the tires myself, if I find where to buy one of the special fittings that are used for this purpose...
That is where my head is at the moment.
New Holland 650 Hay Baler (A53317)
New Holland 650...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2014 Volkswagen Jetta Sedan (A56859)
2014 Volkswagen...
2012 International (A55973)
2012 International...
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
