foam filled tires? is it possible to DIY??
   / foam filled tires? is it possible to DIY?? #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Getting tired of having to patch and replace tubes.
Would like to look into foam. The only place I know that can do it near me, actually sends them out. really don't want to be without tractor for a week. And nor sure what it cost either.
I'm actually on a job today and just hat to leave for 2 hrs to patch yet again.
So a few questions:
1. What is the Norman cost for 2 7x16's?
2. Any places in central oh.
3. Is their a way to DIY?
   / foam filled tires? is it possible to DIY?? #2
Why are you getting flats? Are you in thorn country or just old tires? We have a product that we get that leaves a coating on the inside of the tire that prevents a lot of flats.
Thorn country. briars, hawthorn trees, locust, etc. I Just want to foam and be done
   / foam filled tires? is it possible to DIY?? #4
Try Gemplers. Don't remember if they have foam but I think they have other sealers.
   / foam filled tires? is it possible to DIY?? #5
Mount the tires tubeless and put in some tire sealer. Foam will be hard on front end
   / foam filled tires? is it possible to DIY?? #6
+1 to this. You could end up doing more harm to your tractor as the shock normally absorbed by the tires will be transferred to the axles and other front end components leading to breakage. I had an 1120 JD with a 145 loader that I mounted a 7' stone fork on. I ran front air at 45 psi and broke several front spindles. When I backed the air off to 35 psi no more broken spindles. YMMV.
   / foam filled tires? is it possible to DIY?? #8
a google search will find a couple places that will sell you a DIY kit..
I want to fill a handcart, wheelbarrow tires but havent gotten motivated enough to look into it more
brian
   / foam filled tires? is it possible to DIY?? #10
My uncle bought a used Bobcat. It rode harder than his old Bobcat. He discovered it had foam filled tires. I do not believe he was fond of the foam ride. I have had fair success with Slime and other products. I cut down and burn locust, and two other species that have messed up a few tubes. Blackberry briars has never hurt my tires. My neighbor has some foam filled tires on one of his JDs but all I used it for was moving round bales in the yard by the hay barn.. I have no idea how it performs out in the field.
5ft Serrated Hydraulic Dozer Blade Skid Steer Attachment (A55851)
5ft Serrated...
UNUSED JCT 72" HYD TILLER (A57193)
UNUSED JCT 72" HYD...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2014 International Maxxforce DT (A53317)
2014 International...
2022 Brush Wolf 7800-HF Skid Steer Brush Cutter (A57024)
2022 Brush Wolf...
PT 250 Gallon Fuel Tank (A56469)
PT 250 Gallon Fuel...
