Foam filled front tires?
   / Foam filled front tires? #1
TmbrWlkr
Kubota l3400
I am soon to take possession of a new Kioti DK5010. My property has lots of Hawthorne trees, which in the past have punctured the front tires of my Kubota l3400. I plan to wage war on these obnoxious trees with a Titan tree puller.
My question is - thoughts on filling the front tires with foam ( has worked well for me with skid steers on demo sites).
Benefits I can see are puncture proof and possibly increased loader capacity. Downsides are cost, and when they wear out you need to buy new rims.
Am I missing something?
   / Foam filled front tires? #2
My bobcat owner's manual says not fill front tires with anything and not to fill rears with foam. Kioti is the same tractor. Check manual for warranty issues.
   / Foam filled front tires? #3
This is what I am running on my DK4510 (I have Locust trees).
I use the regular kind in my front tires, the "ballast" version for my rear tires.
Thanks - will check on that. I know that it increases the wheel weight substantially - maybe that’s the issue.
   / Foam filled front tires? #5
They’re going to ride quite a bit harder and the hard ride could negatively affect the front axel.
   / Foam filled front tires? #6
The regular Liquitube isn't a fill, it is like Slime but I believe is a better formula. I used Slime in my old tractor, originally wasn't going to add ballast to rears on my new tractor because of the issue with the Locust thorns, thinking you couldn't use sealant with ballast. I stumbled across Liquitube and felt that was a good solution. They have a version for both ballast and non-ballast. For my DK4510 it took 1 gallon of the Premium Sealant for front (1/2 gal each tire), 10 gallons of Ballast Seal for rear (5 gal each tire). I used RV antifreeze for ballast; non-toxic, less messy.
   / Foam filled front tires? #7
I keep running over stuff clearing a section of my land and after my 3rd plug I went to slime.
I have been running Slime in my front tires for a wile now and I have not had to plug my front tires ever since.
   / Foam filled front tires? #8
I have been running foam filled tires (on the front) happily for 19 years and 1800+ hours on my B2910 Kubota. Fair amount of loader work during that time. And 18 years on the front of my smaller BX2200.
Would do it again in a heartbeat.
   / Foam filled front tires? #9
I have foam in the front tires of my tractor and my backhoe. I went from using slime, which is great for awhile, but eventually breaks down and ruins the tire for a patch, so I went to tubes, which where OK, but I still got flats fairly often.
I'm on my second set of tires for the tractor. The foam causes them to wear out faster. These are R1's and that might contribute to it. My backhoe is 2wd and the tires are smoother. There is no wear on the backhoe tires. The cleats crack and start to fall apart afte7 years of use. They used the same rims when they foamed the new tires.
The foam makes the tires super heave. I think this increases traction on my tractor. the backhoe doesn't matter since it's 2wd.
The ride is the same in my opinion.
The weight of the foamed tire is on the ground, and the weight of the tractor is on the tire, so there is no additional weight to the tractor, unless you count the effort to make them roll, which is insignificant in my opinion.
I have not lost a day to a front tire going flat since foaming them. Before, it could be as often as twice a month. I've had a few flats in my rear tires over the last 15 years, but they are both still the original tires and I'm guessing I've only had half a dozen flats on both tractors rear tires combined.
What is the % mix of pavement/dirt that you are running your tractor on - and what implements are you using?
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2004 CATERPILLAR 963C CRAWLER LOADER (A51242)
2004 CATERPILLAR...
LandHonor 15,000lbs Hydraulic Logging Winch Skid Steer Attachment (A49462)
LandHonor...
2006 International 4400 LP Ambulance (A50323)
2006 International...
Kewanee 15' Disk (A50515)
Kewanee 15' Disk...
