MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 66,352
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
OK, substitute corn field for mountain and you got Indiana. At least the upper half of the state.
The car has ABS and brake balancing. It my even have Subaru's 4 wheel electronic skid control, called VSC. In my WRX VSC can be turned off, not sure about this one.That car is new enough that it should have had anti-lock brakes, so unless something failed, the tires shouldn't have locked up.
There is another possibility. If the wheels were turned to the left (which is likely based upon how the car moved) there would have been skid marks left from the tires scrubbing sideways. If you look at the skid mark caused by the left front tire, it's very narrow and the mark from the right front is very heavy. That would be consistent with the wheel turned to the left and more weight on the right front. There doesn't appear to be any fourth skid mark of note from the left rear tire...it would have had the least weight on it in that situation, so the least traction.
Regardless of whether the brakes were locked up, or he didn't counter-steer, it's a total fail as far as driving skills go.
I was curious and looked it up. Most of Indiana is at 800-1,100 ft above sea level. Hoosier Hill is 1,257 feet.OK, substitute corn field for mountain and you got Indiana. At least the upper half of the state.![]()
Nope, the tow truck driver put "dollies" under the front wheels, so all wheels are off the ground. You can see them at 1:59: https://youtu.be/S5NWcdq4Wf4?t=119BTW it appears the tow truck towed it away with the front wheels on the ground. There is no way to shut AWD off in these cars, so that tow driver just destroyed his center viscous drive.
I was curious and looked it up. Most of Indiana is at 800-1,100 ft above sea level. Hoosier Hill is 1,257 feet. So - more hills than Florida!
Drive Southern Indiana. It's totally different where I live now compared to Northern Indiana. We have a hill I travel every day that's a 6% grade for 7 miles.
Chris
https://archive.org/details/DuelingBanjosSouthern Indiana is northern Appalachia.... drive faster, I hear banjo music.
But its hardly mountains. More like hills with attitude.
Southern Indiana is northern Appalachia.... drive faster, I hear banjo music. But its hardly mountains. More like hills with attitude.
