Flushing the Hyraulic lines
   / Flushing the Hyraulic lines #1
Pooh Bear
Lakeland,La
Mahindra / 3616
I am new to the world of hydraulics. I just purchased a used Bushhog BH and didn't want to contaminate the hydro system on my new tractor with the old fluid still in the lines. I have no idea how long it has been sitting up. The BH dosen't have a pump ,it runs off the tractors hydro system. Can someone tell me how to flush the lines properly ? Thanks in advance for all help. Jason Robin
   / Flushing the Hyraulic lines #2
Remove cyl from cutter and manually move ram in/out(vice-verse) until old oil is purged from cyl & hoses.
   / Flushing the Hyraulic lines #3
yep, also have to remove quick connects. If you really want to do it right pull hoses and spray them and cilender out with carb cleaner and let dry before you put back together, but that is prob. overkill.
I check the system and all fluids were up to par. After months of waiting to mount the BH,I finally was able to use it. All I can say is WOW,what a awesome piece of equipment. Thanks for all the help
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
LOT IDENTIFIER 234 (A53084)
LOT IDENTIFIER 234...
1998 C6500 Chevy, 3126 Cat Engine (A52384)
1998 C6500 Chevy...
2019 Dodge Ram 5500 Tiger Crane 6545EP 6,500lb 3 Ton 4x4 Crane Service Truck (A51692)
2019 Dodge Ram...
TROYBILT TB51BP GAS BACKPACK BLOWER (A51248)
TROYBILT TB51BP...
UNUSED FUTURE HYD 16" AUGER (A51248)
UNUSED FUTURE HYD...
