Flushing Rear Fluid
   / Flushing Rear Fluid #1
Rocky1992
I just drained the fluid from the rear of a 1994 1520 Ford 4X4, I noticed some metal filings in the oil. Is there anything out there that I can run through to flush it out?
Thanks
   / Flushing Rear Fluid #2
metal filings are always a scarry thing to find when draining any oil sump.
if you don't have a magnetic element ont he oil plug I'd go buy a small button rare earth magnet and stick it on there anfter cleaningthe plug.. glue it on with a drop of superglue.
now then.. for a flush? I have usually flushed my old fords with a mix of atf and diesel when i get then as a baseline to get all the old oil out.
your call if you want to do that or not.
past that.. refill with good oil, and service again if you notice any odd noises or differences in handling.. and then see if you are getting more metal shavings.
if you are lucky, it was either not serviced and those are left over from the manufacturing process.. or it was just accumulated incedental metal from the gears.
soundguy
2007 Trail-Eze TE80HT48DD 48ft 48 Ton T/A Hydraulic Dovetail Trailer (A51692)
2007 Trail-Eze...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A53473)
John Deere 1110...
2025 K0520 UNUSED (5) Welded Wire Mesh Roll (A53117)
2025 K0520 UNUSED...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51691)
2016 Ford F-550...
2020 VOLVO VNL64T740 TANDEM AXLE MID ROOF (A53426)
2020 VOLVO...
Caterpillar 330L Excavator (A52384)
Caterpillar 330L...
