Fluids?????
   / Fluids????? #1
Carl1
Dayton,Ohio
IH 574 and IH424,Ih3414 loader
Bought a old tractor. in the process of changing fluilds. Can you use the same fluid in the tranny and fel??
thanks
   / Fluids????? #2
Carl,
I think we could all give you a better idea if you tell us what kind of tractor you have. Most newer ones use the same, in fact they use the same resevoir. But the older ones I can't tell you for sure.
murph
   / Fluids?????
Sorry,
IHC 3414 international loader built in the 60's
thanks
   / Fluids????? #4
Yes the 414 should use Hytran or the equivalent in both the loader and the tranny. I use the Premium UTF from Tractor Supply, as long as it meets the Hytran specs it should be fine.
I suspect you tractor uses a common sump in the tranny anyway, my 1968 2444 does.
You will have about 3 drain plugs on the bottom to pull, and possibly one on the rear of the lift box assembly, depending on your configuration.
KUBOTA SVL75-2 SKID STEER (A52705)
KUBOTA SVL75-2...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
UNUSED (2) 7000# DROP AXLES W/ BRAKES (A54756)
UNUSED (2) 7000#...
2008 GMC C5 (A53422)
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
JOHN DEERE 444-624 - 60" LOADER FORKS (A52705)
JOHN DEERE 444-624...
