Fluid! Where does it go?
/ Fluid! Where does it go? #1
Sully2
Cincinnati, OH
Kubota B3030
Was reading a thread here the other day about front end lube..and thought Id check mine. LOW! Dont know when it got that way...but it took a qt to get it back up to the top of the indicator range.
I have NO LEAKS..anywhere. So where did the front differential lube go to???
/ Fluid! Where does it go? #3
In my limited experience, leaking fluids go in two directions:
1. Downhill
2. Towards uninsured items.
I SHOULD have known better than to ask...LOL
/ Fluid! Where does it go? #5
Well my first thought was do you live around a plant that makes oil eating microbes?? ;)
But I bet is wasn't full to begin with.
/ Fluid! Where does it go? #6
Especially common on the front axle is that when you fill the axle to the level indicator the oil has yet to fill the lower bevel gear cavities fully. It's tough for oil to get in there and for the air bubbles to get out.
/ Fluid! Where does it go? #7
Whenever you fill up with oil, you can be sure that gravity is taking it down.
And I thank you MUCH for an answer I can finally live with SIR...:)
(oil eating microbes my ***.....lol)
/ Fluid! Where does it go? #9
I really mean it, no joking, the level went down in my FWD axle over time and I needed to top it off twice. It has since stopped settling. I had no leaks either so it seemed to make the most sense that the oil needs to work down in through the bearings and tight clearances to fill those low reservoirs.
Makes sense to me for sure. I have oil filled front wheel bearings on a motorhome. Drain them and "refill"..and ALWAYS the next day have to come back and add more. It take some amout of time for fluids to "squeeze" thru everything to seek the correct level.
/ Fluid! Where does it go? #11
I always recheck my axle oil level the next day. Easy to do.
Bob
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
Enclosed Trailer with Lube System (A62613)
Enclosed Trailer...
UNUSED WOLVERINE MCB-11-48W 48" HYD 4N1 BUCKET (A64281)
UNUSED WOLVERINE...
40' CONTAINER (A64281)
ATLAS TC-229 ELECTRIC/AIR TIRE CHANGER (A64281)
ATLAS TC-229...
30" X 12' ADS DRAINAGE PIPE (A64281)
30" X 12' ADS...
