Fluid Type
   / Fluid Type #1
zubin6220
I recently purchased a log splitter which calls for 9 gallons of hydraulic flluid. My question is - can I use the standard type that I use in my tractor? Thanks in advance.
   / Fluid Type #2
You mean like AW32 regular hydraulic fluid?
If so, yes. Even if it's tractor hydraulic/transmission oil it should be OK to use. The cylinder on your log splitter works the same as the ones on your tractor, IMO.
   / Fluid Type #3
AW-32 should be fine. Check your owners manual. If you are using it in 32 degrees or below, I would use ATF. In the forklift industry where they frequently use machines below 0 degrees and lower, they use ATF for hydraulic fluid.
   / Fluid Type
Just what I needed. Thanks
   / Fluid Type #5
My log splitter called for ATF 22ton MTD (I don't used under 40f) -Ed
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
50ft Fuel Line (A51573)
50ft Fuel Line...
Sears/Craftsman Shredder (A51573)
Sears/Craftsman...
MANLIFT (A52472)
MANLIFT (A52472)
2022 Wacker Neuson SM100 Mini Skid Steer (A53472)
2022 Wacker Neuson...
