marceldig
I just completed my 50 hour service on my L3000F. I followed the instructions in the owner's manual for changing the hydraulic fluid and drained all four plugs and removed and cleaned the strainer. As indicated by the manual, I refilled to the upper line of the indicator lens. I put in about 7 gallons (spec's indicate a 7.4 gallon fill), about 5 gallons in the front fill plug and about 2 gallons in the rear. I then started the engine and ran it for a few minutes and checked the gauge again. The lens indicated no fluid level, so I put the remainder of the 3rd 2.5 gallon bottle of UDT into the front fill plug, started it again, and still no level in the site glass. I added another ½ gallon, ran the motor for a few minutes, turned the steering wheel to activate the power steering, and raised and lowered the hitch a few times. Still no level in the site glass. I was unable to drive the tractor at that time, but my next step is to drive it around the yard a few times and check the level again. I also put all the used fluid into the same three 2.5 gallon containers, so I'm reasonable sure that there was about 7.4 gallons in the tractor before I drained it and the site glass indicated full. Am I missing something? Thanks for your help.
