Fluid Leak
/ Fluid Leak #1
AMR
Woodbury, CT
B3030
I have a BX23 with 34 hours and I have the plow on it right now. I noticed a couple drops of hydro fluid under the machine where the hoses to the quick attach and plow connect to the machine (the same spot the front loader connects). I have been watching them very carefully, it appears that after I run it for a while a drop of fluid forms on two of the quick attached couplings. I have taken them on and off, etc. and I can still see a drop form once in a while. Not really enough to reliably repeat but enough that in a weeks time a drop does form. Thoughts?
/ Fluid Leak #2
It doesn't sound like it's much to worry about. There should just be o-rings in the quick connect and if the problem persists you could change the o-rings. Make sure your fittings are clean when you connect them to prevent future wear.
I also saw where you are planning on bringing it to the dealer for your 50 hour service. I'd let them know and I'm sure they wouldn't mind changing the o-rings out for you.
/ Fluid Leak #3
Also some times one or more of the couplings are not tight enough on the lines.
Be sure you are confident where the leak is occuring before attempting a fix. At 34 hours I would hazard a guess that warranty would pay for any fix.
A drop every now and then is more of an aggravation than a serious problem.
I had a similar problem on my BH couplings that I ignored and it seems to have corrected itself strangely enough.
All the best,
Martin
/ Fluid Leak
Thanks guys, I will take a good look at them and let the dealer know as well.
2007 INTERNATIONAL 7600 6X4 T/A VACCUUM TRUCK (A66091)
2007 INTERNATIONAL...
2123 (A65055)
2123 (A65055)
2011 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2011 Ford F-250...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A65053)
KNOW BEFORE YOU...
2024 FORD F350 4X2 CREW CAB & CHASSIS PICKUP TRUCK (A67148)
2024 FORD F350 4X2...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
