Mowing Fluid in tires on a zero turn mower?
   / Fluid in tires on a zero turn mower? #1
WINSTONSM
Tennessee
Looking
Has anyone had any experience with putting fluid in tires on a zero turn mower?? Does it help stability and traction??
Thanks!!
   / Fluid in tires on a zero turn mower? #2
I have not, but it might have some drawbacks, due to the way they turn. They could be pretty rough on your turf. I am curious to se if anyone has tried it.
   / Fluid in tires on a zero turn mower? #3
EX-MARK WILL drop your warranty if you use it, it says it in the manual.They say it will ruin your hydraulics.
   / Fluid in tires on a zero turn mower? #4
Lightness is disirable in a ZT mower, why would you add weight. I have a 75 lbs counter weight that I mount at the front to offset the bagging system for my leaf vac. I don't like weight there unless I am using vac because it affects the handling particularly when turning.
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
UNUSED CFG Industrial QK16R Mini Excavator (A47384)
UNUSED CFG...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
1261 (A50490)
1261 (A50490)
UNUSED FUTURE MINI EXCAVATOR COUPLER (A51244)
UNUSED FUTURE MINI...
