Mowing Fluid in tires on a zero turn mower?
   / Fluid in tires on a zero turn mower? #1
WINSTONSM
Tennessee
Looking
Has anyone had any experience with putting fluid in tires on a zero turn mower?? Does it help stability and traction??
Thanks!!
   / Fluid in tires on a zero turn mower? #2
I have not, but it might have some drawbacks, due to the way they turn. They could be pretty rough on your turf. I am curious to se if anyone has tried it.
   / Fluid in tires on a zero turn mower? #3
EX-MARK WILL drop your warranty if you use it, it says it in the manual.They say it will ruin your hydraulics.
   / Fluid in tires on a zero turn mower? #4
Lightness is disirable in a ZT mower, why would you add weight. I have a 75 lbs counter weight that I mount at the front to offset the bagging system for my leaf vac. I don't like weight there unless I am using vac because it affects the handling particularly when turning.
2012 PETERBILT 337 (A50854)
2012 PETERBILT 337...
1042 (A50459)
1042 (A50459)
2019 CATERPILLAR 315FL CR EXCAVATOR (A51242)
2019 CATERPILLAR...
(2) ALEMITE GREASE HOSE / REEL & NOZZLE W/ GAUGE (A51244)
(2) ALEMITE GREASE...
2015 MACK CXU613 TANDEM AXLE DAY CAB (A52141)
2015 MACK CXU613...
Quick Attach Pallet Forks (A47384)
Quick Attach...
