Ballast Fluid in the front tires?
   / Fluid in the front tires? #11
The biggest problem I would see is if you have a FEL with a reduced amount of air in the tire there would be less abillity for the tire to carry heavy loads. Air can compress where as water will not.
   / Fluid in the front tires? #12
Tires are never filled past 75% so there is always air in the tire.
   / Fluid in the front tires? #13
:confused: Why would the tire lose ability to carry just because theres water in it :confused2:
larry
   / Fluid in the front tires? #14
I put Rimguard in all 4 tires on my JD 3320. No issues in two years. I keep the fronts blown up to max. pressure from the manual.
Dan
Thanks for all the advise guys. I'm looking at purchasing a new 3032E in a month or so and was curious if I could add liquid to the front tires v/s using suit case weights. I will not be purchasing a loader at this time so I was wanting to add more weight to the front to help counter balance any implements that I may be using. Plus it should add more stability if all 4 tires were filled. I will talk to my JD dealer also. Thanks again. :)
UNUSED FUTURE DEER SHAPED SHOOTING TARGET (A57193)
UNUSED FUTURE DEER...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A57024)
Ditch Witch 6510A...
UNUSED FUTURE GR87-87" HYD GRADER BLADE (A57193)
UNUSED FUTURE...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
