Fluid in front tires?
   / Fluid in front tires? #1
bilrus61
Platinum Member
kubota 4200
My incomming Kubota L5040 has 9.5-16 tires. The Rimguard website shows that it would add about 125 pounds per tire if filled with Rimguard. Thats considerable. 250 pounds total way out front would certainly keep my front end solid on the ground even with a heavy mower on the back. What is the bad side of filling the small front tires? A rougher ride I would guess. Anything else??
   / Fluid in front tires? #2
I don't have any experience with Rimgaurd. But, I can share my experience with foam filled front tires. I was a mechanic for a landscape contractor for 8 years. We foam filled all of our front tires including our Kubota M6040 that we used as a grading tractor, plus half a dozen B2710's. We also had a few New Holland TC55's and TC33's, and 2 case 570LXT's. I would consider solid foam filling to be much harsher on parts than liquid ballast could be. And I never noticed any acceleration in parts attrition except on the Cases. After having the fronts recapped a few times the centers would bust out of the wheels.
Brian
   / Fluid in front tires? #3
Brian
What kind of foam did you use?
   / Fluid in front tires? #4
Maybe if you didn't have a FEL then loaded fronts would be OK. It sounds like that is your situation.
Turning weighted tires has to be more difficult on the steering components.
If you do have, or will get, a FEL the weight of a loaded bucket will already put tremendous downward force on the front tires/axle.
Also, if you have a FEL you can scoop up some dirt or gravel and have a very effective front weight for balancing a heavy implement on the rear.
   / Fluid in front tires? #5
It was a poly-ethelene foam which made the tires solid and it was quite heavy. There are different compositions for different applications. I left that to my tire guy.
Brian
   / Fluid in front tires? #6
+1 :thumbsup:
   / Fluid in front tires? #7
I will have to check my manuals, but I seem to remember one says not to load the front tires.
   / Fluid in front tires? #8
Why not just hang some suitcase weights on the nose? Less wear and tear on the steering components, and you can adjust weight as necessary.
   / Fluid in front tires? #9
I have no dog in this fight, but does transferring the weight from the tires to the front of the frame really change the stress on the steering components? Seems to me the weight on the frame is actually adding stress to more components, not less.
Of course, depending on the weight, this may be irrelevant.
   / Fluid in front tires? #10
Think about this guys. Weight is weight, whether it is on the frame as front weights, or in the loader bucket, that weight gets transfered to the front tires and axles. Wheel weight is probably the most efficent because half or more (if liquid ballast) of the weight is underneath the axle. Solid tires create issues, not because of the weight but because air filled tires act like shock absorbers, when you take the air out you get a much more rigid ride so every shock loading situation gets amplified. With liquid ballast you retain a good portion of air space in the tire, so things aren't as harsh. Like I said, even with solid foam filled tires on our Kubota and New Holland machines I did not notice any accelerated wear and we put thousands of hours on these machines.
Brian
2015 CASE 580N (A47477)
2015 CASE 580N...
Lift Gate (A52377)
Lift Gate (A52377)
2803 (A50460)
2803 (A50460)
2009 INTERNATIONAL PRO STAR+ (A53843)
2009 INTERNATIONAL...
378812 (A51573)
378812 (A51573)
RIGID POWER DRIVE/HAND HELD THREADER (A53843)
RIGID POWER...
