fluid for satoh 650 governor
   / fluid for satoh 650 governor #1
Haybarn
Apologize for the dummy question, but what fluid is used in the governor on a Satoh 650? Also, can anyone recommend a place to buy a repair/rebuild kit for one of these?
Many thanks
Dave:confused:
   / fluid for satoh 650 governor #2
It has a seperate sump from the engine? Or are you refering to the diesel injector pump oil?
soundguy
   / fluid for satoh 650 governor #3
It uses engine oil. Having had to rebuild mine, I suggest draining the old oil out every couple years. Previous owners apparently had not checked it often/ever and since it is not sealed enough moisture had gotten to make a real mess.
As far as the rebuild goes I did mine myself. Do you have a repair manual? It's fairly helpful, but I ended up doing some minor modifications to mine. If you're not interested doing it yourself, there are a couple TBN members who offer parts for these. They frequent the Satoh section often. One is lens12 (sheaf tractor) and the other is BillRogers (valley equipment). IIRC is spoke with Bill when rebuilding mine and he was helpful even though I ended up buying all the parts I needed through a local industrial supply house. (One advantage of being an mech eng is knowing how to spec and get things like bearings, seals, etc..)
2019 John Deere 5075E (A50123)
2019 John Deere...
2025 K2223 UNUSED Double Garage Metal Shed (A53117)
2025 K2223 UNUSED...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2025 KMR 40in Single Cylinder Grapple Skid Steer Attachment (A51691)
2025 KMR 40in...
Genie GTH-5519 (A50123)
Genie GTH-5519...
2019 TY-CROP MANUFACTURING LTD DRY BULK TRANSPORT TRAILER (A53843)
2019 TY-CROP...
