Fluid film Rust Proofing
/ Fluid film Rust Proofing #1
Craig Clayton
Platinum Member
Uxbridge Ontario Canada
L2250 Kubota
Gentlemen
The other day I purchased a 1 U.S. gal of Fluid Film rust proofing to use on my cars/ pickups etc. I was very impressed with it ( NO I do NOT work for the company ) . I purchased it at TSC store but according to the web site it can be bought at the John Deere dealers.I warmed it in a water bath because it is about the thickness of butterscotch pudding that needs to be thinned out for spraying. I spray with a heavy duty hand sprayer on pin nozzle pattern and this lets me get into deep fender spaces.
Fluid Film? | Corrosion Preventative, Lubricant and Rust Inhibitor
Craig Clayton
/ Fluid film Rust Proofing #2
Note that there is already a long thread on Fluid Film entitled "Eureka Fluid Film".
Although effective in certain applications it is not long term effective as a vehicle rustproofing. After reading the thread it has been remarked that it lasts a few months and even the link about using it for undercoating a vehicle recommends annual re-application.
Undercoat My Car
Actual vehicle rustproofing is much more effective in this application since it is designed for that purpose. I just recently checked my truck, which I did rustproof with commercial vehicle rustproofing, and after 3 years the rustproofing is just as it was applied and still 100% effective.
/ Fluid film Rust Proofing #3
Undercoat My Car
What "Actual vehicle rustproofing" did you use ?
/ Fluid film Rust Proofing #4
The product name is RustFre or something like that. Available, along with applicator gun, at Body Shop Supply stores. Has worked extremely well.
/ Fluid film Rust Proofing #5
Fluid Film is the closest thing to the factory wax coatings that I can find. Other formulations outside of the spray can, leave a thick grease like coating. While it can wash off in heavy, constant flow (like wheel well areas), its remarkably resilient. I've had excellent results with fluid film as an underbody coating.
2018 Cat D6T LGP VPAT Dozer (A62679)
2018 Cat D6T LGP...
2019 GMC Canyon SLE 4X4 (A62679)
2019 GMC Canyon...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
Mini Universal Tree Spade (A65640)
Mini Universal...
1/2" Quick Attach Blank Plate (A66408)
1/2" Quick Attach...
