Fluid change on Jinma LE 284
   / Fluid change on Jinma LE 284 #1
leslie428
Québec, Canada
Jinma 284 LE IH 434 with loader
Could someone please take some pictures and show us exactly where we need to go to check fluids and where the plugs are that need to be removed to properly remove all the fluids. Reading some of the threads would indicate that some want-to-be tractor experts like me really are uncertain about this. Thanks for your help.
   / Fluid change on Jinma LE 284 #3
Very nicely explained DIY. I'm sure many people will find your article very helpful....
John
Thank you, excellent article with great pictures. I think I am back on track.
   / Fluid change on Jinma LE 284 #5
<font color="blue"> I think I am back on track.
Leslie </font>
Hey Leslie,
If you have a problem locating all the drain plugs, just ask, and I am sure that someone here, will help you locate them.
3 drain plugs on the front drive
1 drain plug on the transfer unit
1 drain plug on the creeper gear reservoir
2 drain plugs on the transmission
1 drain plug on the hydraulic reservoir
1 drain plug on the engine
and if I remember correctly, there are 2 drains on the fuel injector pump. /forums/images/graemlins/shocked.gif
All these drain plugs can drive a person to drinking, but it's really not hard, once you've located all of them and done it once or twice.
Get your tractors running &
Have a nice day,
Joe /forums/images/graemlins/cool.gif
   / Fluid change on Jinma LE 284 #6
This really helpful. Do you have anything for the Y385T
Sincerely,
-Ross-
Elgin, AZ
Double R Heart Ranch
   / Fluid change on Jinma LE 284 #7
This link is no longer available. I have a 2005 Jinma 284 that I need to change all the fluids on. I'm fairly sure I've found all the drains but would feel better if I saw photos of all points. I've searched through MANY posts for this info but have yet to find what I'm looking for. This link sounded promising but, as I said, it's no longer any good. Thanks in advance for any responses.
   / Fluid change on Jinma LE 284 #8
2012 Chevrolet Cruze LS Sedan (A50324)
2012 Chevrolet...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
2004 Ford F250 (A50515)
2004 Ford F250...
