Fluid change in front end of 2520
   / Fluid change in front end of 2520 #1
BlackRaptor
SEMN
John Deere 3320
Well my 2520 has 75 hours on it now I changed all the main fluids on the tractor at 50 hours oil tranny so on.
But i did not change the fluid in the front end for the AWD.
should i change this before the mowing season starts? I remember someone saying 100 or 150 hours before changing this fluid
Thanks
Chad
   / Fluid change in front end of 2520 #2
   / Fluid change in front end of 2520 #3
Why so early? Not saying good or bad but I had my 650 for 20 years never changed the frontend oil, 1500 hours and a lot of 4 wheel drive. I think the manual states 600 hours.
   / Fluid change in front end of 2520 #4
I changed my 2320 @ around 100 hours.. I just wanted some fresh in there and I also went with Amsoil Severe Gear 75-90..
The oil coming out had a murky color to it, almost like it may have had some water contamination.. My drain valves at each tire were sorta hard to drain without getting oil all over the rims.. I cut the bottom out of a 20oz plastic drink bottle and used that to direct the flow away from the tires into a pan..
The refill is a slow process, at least on the 2320. At times it would get air locked/bubbles and over flow because i was trying to pour too fast. Then it took several days of driving and rechecking to get it all the way to the full mark - I assume it took that long to get it into both wheel cavities..
Brian
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2019 GENERAC MLT6SK-HERC LIGHT PLANT / GENERATOR (A52706)
2019 GENERAC...
New CFG 680 Skidloader Pounder (A50775)
New CFG 680...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
33ft Dovetail Flatbed Trailer (A55301)
33ft Dovetail...
2015 JOHN DEERE 250G LC EXCAVATOR (A52705)
2015 JOHN DEERE...
