Fluid Capacity's
/ Fluid Capacity's #1
Momboy007
San Diego
Jinma 304
Fluid Capacity\'s
Hello All again,
I have a Jinma 304 with a FEL and was wondering if anyone here knows the capacities of the fluids that I plan on replacing this Weekend.
My manual says that the Engine holds 6 Litres, but from reading here I think 4 Quarts is the actual. Would this be correct, also my manual is wrong all over the place and I feel that I cannot trust what it says, for instance, it says my Engine is a 2 cylinder model and the list goes on and on.
Thanks for your help
Rick
P.S. I will push through all this!
/ Fluid Capacity's
Re: Fluid Capacity\'s
Oh Yea /forums/images/graemlins/tongue.gif
How about all the other chamber volumes
Thanks again in advance,
Rick
/ Fluid Capacity's #3
front axle takes about a gallon,trans about 5 1/2 gallons. lifter box holds about 3 gallons, but you will need more to flush it out. injector pump takes about 6 to 8 oz, depending on what pump you have, old style without dip stick or new with a dipstick. takes the same oil as the engine oil.
engine oil with new filter take about 5 quarts, be careful the hard rubber boot on the dipstick will stick in the hole sometimes,DON'T push it into the oil pan, slide dip stick back in real easy and twist and try to pull the boot out,bad design, but can be fixed if you solder a small washer above and below the boot on the dip stick
Depending on stomach room 2 to 6 beers
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2014 MERCEDES 2500 CARGO VAN (A67147)
2014 MERCEDES 2500...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
New/Unused Wolverine 44in Mini Grapple Bucket (A65583)
New/Unused...
