Fluid Capacity's
   / Fluid Capacity's #1
Momboy007
San Diego
Jinma 304
Fluid Capacity\'s
Hello All again,
I have a Jinma 304 with a FEL and was wondering if anyone here knows the capacities of the fluids that I plan on replacing this Weekend.
My manual says that the Engine holds 6 Litres, but from reading here I think 4 Quarts is the actual. Would this be correct, also my manual is wrong all over the place and I feel that I cannot trust what it says, for instance, it says my Engine is a 2 cylinder model and the list goes on and on.
Thanks for your help
Rick
P.S. I will push through all this!
   / Fluid Capacity's
Re: Fluid Capacity\'s
Oh Yea /forums/images/graemlins/tongue.gif
How about all the other chamber volumes
Thanks again in advance,
Rick
   / Fluid Capacity's #3
front axle takes about a gallon,trans about 5 1/2 gallons. lifter box holds about 3 gallons, but you will need more to flush it out. injector pump takes about 6 to 8 oz, depending on what pump you have, old style without dip stick or new with a dipstick. takes the same oil as the engine oil.
engine oil with new filter take about 5 quarts, be careful the hard rubber boot on the dipstick will stick in the hole sometimes,DON'T push it into the oil pan, slide dip stick back in real easy and twist and try to pull the boot out,bad design, but can be fixed if you solder a small washer above and below the boot on the dip stick
Depending on stomach room 2 to 6 beers
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
Ditch Witch R 40 (A52384)
Ditch Witch R 40...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2016 KIMB Garbage Truck (A51692)
2016 KIMB Garbage...
