Fluid and power steer
/ Fluid and power steer #1
mbull
2005 L2800.
My power steering seems week or binding. Tractor has 90 hrs., no front end loader.
Did filterr change, no help. Fluid looked OK.
Should I change fluid also?
Where do you drain it?
What is refill capacity?
Thanks in advance for any help.
Can anybody give suggestions?
/ Fluid and power steer #3
90 hours in 4 years??
Most folks change hydraulic fluid after 50 hours. At 4 years many owners might change it out of boredom.
Assuming the hydraulics work, about half of steering problems are due to leaking o-rings in the steering ram. Yours have been sitting unused so much, could see that happening.
Worst thing you can do to a tractor is not use it....
Would these leaking o-rings be visible? There are zero signs of leaks anywhere on this tractor.
/ Fluid and power steer #5
No, they are internal to the steering ram, between the opposing hydraulic loops.
However, a leak there won't make the steering wheel bind. The steering wheel still turns, just the steering doesn't follow.
Problem solved. Filters and fluids were not the issue. I remembered reading a post awhile back about return line (from filter to hydraulic pump) that was prone to cracks. Took rubber line off, found crack, replaced, all is like new.
/ Fluid and power steer #7
Glad to hear that you solved your problem but yes, 90 hours in 4 years :confused:? I would proceed with the 50 hour service regardless if you solved the steering problem.
Welcome to TBN!!!
