fluctuating ammeter
   / fluctuating ammeter #1
klink
Ohio
Ford 660,JD 4110 Hydro - JD 670 gear - 48 Farmall Cub - 51 Farmall H - John Deere 50 - JD X540 JD X580 AC 917 WH 81 Cub Cadet 1541 & 70
my John Deere 520 when the engine is running the tractor ammeter fluctuates radically on both sides of 0. Just bought the tractor and it has a new battery in it. It has all original wiring and still has a 12 volt generator with positive ground. the battery voltage seems be ok, with a hand held digital volt-ohm-amp meter the read out fluctuates when taking a volt reading on the battery. My knowledge tells me its either a bad generator, voltage regulator, amp gauge, or a bad connection. just thought I would see if anyone on this forum might be able to help me out? or someone who might of had a simular problem that they fixed.
klink
   / fluctuating ammeter #2
Most likely a voltage regulator issue. Possible that you may be able to adjust it if you remove the cover. If not you may need a new one. I would hook a voltmeter up and see if it fluctuates also. If not, it could be the ammeter is bad.
This JD520 was setting outside for a while { ? } before I bought it, & the battery wouldn't hold a charge, that's why I asked for a brand new battery from the dealer [ I hate to leave anything set outside ] the things I have done so far - I removed the voltage regulator cover and found a lot of moisture & corrosion. I ordered a new voltage regulator and a generator rebuild kit in case I need it now or later. when I turn on the tractor lights with the engine off, the ammeter indicator pointer reads a steady discharge, just like it should. Recapping - before with the engine running the ammeter indicator pointer would fluctuate like a dog wagging it's tail. I think jd110 is right on with the regulator being bad. In my 70 years, I have seen other tractor ammeters act the same way. Anyway I will get it fixed one way or another and I will report back.
klink
Well, I finally got the parts that I ordered, and got them installed. The problem was the voltage regulator. I also replaced the ammeter just in case. So now with the motor running, the ammeter shows the system is charging. With the motor off and I turn on the lights, it shows a discharge. The generator is in good shape, so I have a generator rebuild kit for future use. I have two tractors that use the exact same generator. Thanks for your help.
   / fluctuating ammeter #5
:thumbsup:
Thanks for letting us know.
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2016 KENWORTH T680 TANDEM AXLE MID ROOF SLEEPER TRUCK (A53426)
2016 KENWORTH T680...
Altec Boom Truck Body (A51692)
Altec Boom Truck...
2018 HINO 268  NON CDL 26FT BOX TRUCK (A53426)
2018 HINO 268 NON...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2003 Great Dane 53 ft. Dry Van Trailer (A53117)
2003 Great Dane 53...
