Flowmeter test setup
/ Flowmeter test setup #1
cbailey1956
Bedford, VA
Allis Chalmers B, Komatsu D31, Case 585
Hello, Finally took the plunge and ordered a lake monitor 5-50 gpm flowmeter. Want to build a diagnostic setup and was wondering the correct order of components. Want to install a needle valve, relief valve, and possible a check valve to prevent reverse pressure. I have used OTC and other testers but the plumbing setup is all inside the box. Needed this because I have a lot of components from salvage and teardowns that should be matched for best performance rather than best guessing. Work on AG and Mobile Equipment on the side also and need to be able to properly diagnose systems. Thanks for any help. Currently building a firewood processor and have a lot of valves and two pumps that are unknown as to what they can handle. Craig
/ Flowmeter test setup #2
Craig,
The neatest way to do this would be to use a HIC (Hydraulic Integrated Circuit) / manifold. This would reduce the package size, plumbing leak points, etc. I believe companies like Delta Power Co., Hydra-Force, Sun, etc. all have "pre-engineered" blocks that could be used for this function.
/ Flowmeter test setup #3
Here are some examples.
https://www.cascorp.com/web2/downloads.nsf/0/6E3F57714F8DCB7388257B74007B021B/$FILE/6839920_Flow-PressKit6839908.pdf
(2) TOOL BOXES (A62613)
(2) TOOL BOXES...
2015 Audi Q3 AWD SUV (A61574)
2015 Audi Q3 AWD...
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
Hydraulic rail grinder (A61307)
Hydraulic rail...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
