Flow Rating for Valve Bank in PB Circuit
   / Flow Rating for Valve Bank in PB Circuit #1
Spudland_Dave
Maine
Deere 3520 Cab, Deere F935
So I think I've found an affordable 12v Solenoid controlled valve bank to use in my PB Circuit...before buying it I'd like to know what exactly I should be looking for in terms of GPM Flow, etc...
Tractor its going on is a 3520
   / Flow Rating for Valve Bank in PB Circuit #2
Good Morning. I'm not a hydraulics expert but I spent the night at a Holiday Inn Express :D I was looking at the specs for the 3520 and it lists a total flow of 13.9 GPM and a valve flow of 8.6 GPM. I would think that you would need a valve rated for at least the 8.6 GPM since the PB circuit is flowing through the valve and you would not want to impede the flow for any downstream application.
Thats my biggest question....what number should I use? 13.9 or the 8.6?
   / Flow Rating for Valve Bank in PB Circuit #4
Your tractor has two pumps, one is dedicated to the steering and the other for implements. The 8.6 number is what you want to use-so a valve rated at 10 GPM would be perfect.
Thank you VERY much Kenny!
Glad I asked the question! The valve I had found was 5.3 Nominal, 7.9 Max
back to square one....
UNUSED GOLD MOUNTAIN M122009 12'X20' STEEL CARPORT (A51248)
UNUSED GOLD...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
UNUSED FUTURE BC72 - 72" HYD BLOCK CRUSHER (A51248)
UNUSED FUTURE BC72...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A53472)
Mitsubishi FG35...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
