Flow control
/ Flow control #1
yotehunter66
Bronze Member
Clayton, Mi
1983 Simplicity 9518,1948 Ford 8N , 2013 Yanmar EX3200
I have just installed my grappler on my loader bucket but need to slow down the speed for opening and cloaing. Both way to fast. Would it be best to install two flow control valves or one flow control valve that restricts in both directions?
/ Flow control #2
one in the rod end would prevent the grapple from free falling while closing and also control the opening speed.
/ Flow control
Cool thanks.
/ Flow control #4
Cheaper than a flow control valve is to use a plug in line and drill a very small hole in it to allow a small amount of fluid to pass thru.
/ Flow control #5
It all depends on how you want the grapple to operate.
Slow in both directions or slow in one direction and fast in the other.
/ Flow control
$4 at TSC took care of the problem slowed it down both ways so it stopped slamming. Thanks for the help!
/ Flow control #7
Remember that any oil being bypassed to return creates waste heat.
Any restrictions increase line pressure and fluid velocity as the pump still tries to force the same amount of oil through the smaller diameter.
Not saying it will hurt anything, but you could prematurely wear out your oil or lines.
I'd find a nearby hydraulics shop and ask them if whatever you did with TSC parts will hurt anything.
I deal with hydraulics as part of my job, and anything that only cost four dollars gives me the heebie jeebies.
/ Flow control #8
If $4 part gives you the heebie jeebies, then my fix for controlling the drop speed of my wood splitter wedge would send you into shock. It might of cost me $0.15
/ Flow control
I don't think I'm going to worry to much as this isn't getting used on a daily basis and for hours and hours on end. Regardless of how I do it, while other ways may be more ideal, it will cause a restriction which will cause what you are describing. Just my thinking I guess.
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
(9) SEMI-TANKER TRAILER PARTS (A64280)
(9) SEMI-TANKER...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
2017 Ford Expedition SUV (A61574)
2017 Ford...
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
