Floppy pedals
   / Floppy pedals #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I had an experience today.
Loaded some stuff into the bucket and drove the tractor off trail and dumped the bucket. Went to go backwards, and the HST pedals were all collapsed!
Put it in gear, brake on and shut it down and looked underneath. A pin had come out. I went up hill, looking in the grass and thinking that I'll maybe need to go to the dealer to get a new pin. Then I thought: the forward pedal was working just before I stopped and worked the loader. Looking underneath in the grass, I found the pin. Put it in and backed all the way up to my carriage house ramp and ran up it with the rear wheels up the ramp and parked it there to give me good clearance underneath.
I used a key ring instead of a cotter pin, added a washer that I found and secured the pin again. Lubed it with silicone. Back in business. I used to use a key ring kind of securement on some of the Gravely pins, as they were prone to be grabbed and poked out of place, being so low to the ground. Even had some brush remove the oil dipstick on the Gravely.
Ralph
   / Floppy pedals #2
Ralph
Ahh, sometimes the trees get in the way of the forest. Knew there was an easier replacement, but never thought of something I had in my hand. The key ring.
   / Floppy pedals #3
Thats a first Ralph! Glad to here it was at least a easy fix:D
   / Floppy pedals #4
Glad you found the pin and didn't have to jack up the machine to get under it!
2003 Ford F-250 4x4 Reading Service Truck with Liftgate (A55788)
2003 Ford F-250...
2006 Chevrolet Silverado 1500 4x4 Pickup Truck (A53422)
2006 Chevrolet...
2014 Ford F-150 4X4 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
4-295/75R22.5 Tires And Rims (A50775)
4-295/75R22.5...
