Floppy Bucket Syndrome Cured!
   / Floppy Bucket Syndrome Cured! #1
71 RAT
Deerfield NH.
FORD 821
Want to thank the guys here and think it was the Green Tractor Fourm, for sharing your knowledge and experience. I added an adjustable orifice valve with free flow in the opposite direction. Played a bit with it this afernoon. Seems to work great, a fast dump, but ok with that. Been trying to bleed the dump cyinders for years, thinking it was trapped air. Put up a few pictures. Thanks again!
   / Floppy Bucket Syndrome Cured! #2
Glad you found a work-around for a non-regen valve.
The floppy bucket isnt trapped air....rather air induced every time you dump a heavy load....and gravity extends the cylinders faster than your 6 or 8 gpm pump can replenish the cylinder.
I believe the majority of my FBS education was from your posts. I can thank you directly, for the information.
My loader valve is relatively new, so the reason I went this way. Had I learned at the time, the 821 would have a regen type loader valve.
Thanks Again.
  • Good Post
Reactions: LD1
2007 John Deere 5225 (A50120)
2007 John Deere...
SKID STEER HYDRAULIC TREE PULLER (A52472)
SKID STEER...
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
2010 JOHN DEERE 1110E FORWARDER (A51246)
2010 JOHN DEERE...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
