Floppy bucket on F E L
   / Floppy bucket on F E L #1
Mike Gibson
Dufur Oregon
Kioti CK 27
The bucket on my CK 27 has a point using the curl where it acts like an old bucket truck arm when it breaks over center. It flops back and forth a couple of inches. Is there a cure for this? It acts like air in the line but I'd think by now all the air would be bled out of the cylinders.
   / Floppy bucket on F E L #2
On my JD 200CX loader, there is a rod that runs the width of the bucket and is attached with pins to each bucket holder ("foot") on the ends of the loader booms. It causes the holders to travel equally when dumping/curling (extending/retracting).
I lost a pin out of one side of the rod on mine, and it acted the way you describe.
Not sure if your design is similar, but something to check.
   / Floppy bucket on F E L #3
Mike:
It's part number 12 on the attached diagram.
   / Floppy bucket on F E L #4
A prior dump with weight in the bucket is the likely cause. Not enuf fluild fed to the piston side during the dump so it isnt full/there is a void. Try the fast dump feature [hard right on the joystick] to cure this.
larry
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2012 Kia Sorento SUV (A51694)
2012 Kia Sorento...
2009 Ford F-650 24 ft Box Truck - 6.7L Cummins L6 Engine - Automatic Transmission - Low Mileage (A52748)
2009 Ford F-650 24...
2001 MACK RD688S (A52472)
2001 MACK RD688S...
2012 KENWORTH T370 PROPANE TRANSPORTATION TRUCK (A52472)
2012 KENWORTH T370...
