Floorboard
   / Floorboard #2
Are you asking about the rubber mat? Or is it the metal frame floorboard?
If it is the rubber mat then a lot of folks have used truck bed liner (think LineX) and brush it on. Harbor Freight has it. There are other choices as well.
   / Floorboard
I am talking about the metal frame, a salt water environment is eating the metal. Thanks, john
   / Floorboard #4
Ohh...that a tough one. A couple of choices.
>Ask the dealer about the whereabouts of a tractor boneyard. He/She might have a source for junked tractors for parts.
>Go to a welding shop and ask how much it would be to fabricate a floorboard. They should have a metal bending brake and be able to make one or direct you to one.
>A member on TBN, 4shorts, is excellent at fabrication and may have some good advice. You may want to send a personal message to him. (Who knows, he may show up on this thread.)
http://www.tractorbynet.com/forums/members/4shorts.html
   / Floorboard
Thanks for the reply. There is a metal fabrication shop in Kodiak, I will see if they can build one for me. John
   / Floorboard #6
Have it properly primed and coat it all over with bed liner before installation, says another guy that lives in a salt bath.
   / Floorboard
Thanks, I tried restoring the existing one using bedliner but I was a little late. If I can build a new one, I will for sure treat it.
   / Floorboard #8
Have you priced a new one from Kubota?It may be cheaper than you think.If the floorboard is similar to my B2620,and I think it is,there will be quite a bit involved in making one from scratch,depending on how close you want it to match the original.
   / Floorboard
I just found one from Messick's. $101 plus $65 to ship to Alaska. They ordered it directly from Kubota. Comes in a right and left hand side. I only ordered the left. I found a used one on Kansas for $75. John
   / Floorboard #10
It's a no brainer,you can't get much metal fabrication done for that kind of money and the factory part will always fit and look better.
2013 JOHN DEERE 8235R LOT NUMBER 205 (A53084)
2013 JOHN DEERE...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A52748)
2023 New Holland...
2005 KENWORTH T800 (A52472)
2005 KENWORTH T800...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
Unused Delta Crash...
