floorboard high on L3000DT
   / floorboard high on L3000DT #1
Anonymous Poster
Epic Contributor
i have found the floorboard a little high, at about 23in. my old TO-20 is about 17, and 3/4in.
yes it does make a difference when you are my age. so i am making a step to attach to
the tractor floor, so it will be easier to mount, and dismount. anybody else have this problem?
william l. brown, in wright city, mo.
   / floorboard high on L3000DT #2
Bill, I had the same problem of a high step-up on a Ford 1910; the platform is 24" off the ground and my step reduced it to 18". Conveniently the rear loader bracket ( 1st picture) had a slot that was the same height as the underside of the rear axel with a small spacer (2nd picture). The channel iron I used is also a great to scrape the mud off your shoes ! Every tractor would be different depending what you got to work with. Obviously, I never take the loader off.
I don't know your age, I'm 62 but my knees are a lot older !
RCH<P ID="edit"><FONT SIZE=-1>Edited by Rch on 08/04/01 05:15 PM (server time).</FONT></P>
i plan to make my step from square tubing, this is easy to work with. plan to make a
weldment, and then bolt it on.
ps, i am 72, and i wish i had bought a new tractor 10 years ago.
william in wright city, mo.
Mr. Brown,
You may want to check with your Kubota dealer and see if you can order one already made as an option for your tractor.
I got the above right step and right fender grab handle from my John Deere dealer included in the purchase. An outright price for the kit from John Deere is about $60.
Good luck Sir... /w3tcompact/icons/smile.gif
JOHN,
i can make a step from the material i have on hand, and for a lot less than $60.00
the pictures you sent give me some new ideas. thanks for responding.
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
Veshai PWS-100 2,200lb Electric Pallet Jack (A50322)
Veshai PWS-100...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
2000 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
2000 Mack CH613...
