Floor Options For Pole Barn (Not Concrete)
   / Floor Options For Pole Barn (Not Concrete) #1
The-AJ88
Ohio
In the market
I am interested in having a small 30'x40' pole barn built this year. With everything being expensive these days, I will not have a concrete floor installed for a number of years.
If concrete is not an option right now, what floor options do I have? I plan to park a vehicle and equipment inside the pole barn. The building will not be heated, cooled, or insulated. It will be used for storage only, but I do not want the floor material to lead to rusting my vehicle and tractor. A dirt floor is not an option to me since I do not want to deal with the mud.
Thanks for your input.
   / Floor Options For Pole Barn (Not Concrete) #2
There are various crushed rock options depending on where you are. Most important is to build the barn high and provide lots of drainage so the final floor surface is well above grade. Also make sure you have good roof venting.
   / Floor Options For Pole Barn (Not Concrete) #3
Kenny's end product on his floor is what we should all strive for.
   / Floor Options For Pole Barn (Not Concrete) #4
I would do everything you can to try and get the concrete floor in there now. I did the same thing as you and kick myself everyday for not just putting in concrete when I built it. And now the shed is full of crap that it will be an even bigger job to get it all out of there so i can put concrete in. My shed is on a ridge so it drains really well. I used the smallest gravel I could get for the floor. Have never had any rust problems. Mice on the other hand is a different story.
   / Floor Options For Pole Barn (Not Concrete) #5
you could make nice base with gravel then vapor barrier it and have some 1/4 inch plywood as a floor ... or have a nice base (6'' or so) of 0 - 4'' Granular type II nicely compacted this stuff harden like cement a vapor barrier underneath would also stop the humidity. ... you could do interlock paving stone but I don't think you will want that considering your plans.
   / Floor Options For Pole Barn (Not Concrete) #7
As pthers have said, vapor barried and some sort of crushed material. Perhaps crushed conrete or asphalt millings
   / Floor Options For Pole Barn (Not Concrete) #8
I put in a barn floor about 4 years ago. I had hired a guy to put in a level pad but it was far from level. After the pole building crew was finished I used my tractor to level it out with screened pit run compacted with a plate compactor to within about two inches of final grade and topped it with crusher fines also compacted. Since it was a horse barn I topped that with rubber stall mats. Ours was 36x36 so it took 54 of them at about $50 each, but it made a good floor for the purpose.
For your purposes I would put down a vapor barrier, and use a 3/4 0r 1-1/4 minus crushed material and compact it with a plate compactor for a floor. If it needs a preliminary leveling I used a 2" screened pit run because it was an inexpensive material and didn't have big rocks to make leveling difficult.
   / Floor Options For Pole Barn (Not Concrete) #9
The-AJ88, you are correct about the concrete costs. I had a 32x24x10 pole barn erected this past fall, 2 8x10 overhead doors, one man door, no windows. The barn was 10k. The 4000psi concrete with wire was 3820. The Amish barn builder had suggested that his usual sub contractor would have charged 5000.
The concrete company did a real good job so I was pleased with them.
But, yes, when the concrete is going to cost roughly half the barn build, it makes you take pause.
Like 3 Horse Ranch said, crusher fines are easy to grade and will pack hard.
FWIW, if you had not already considered it, I would have a vapor barrier installed under the roof tin. Nothing worse than having condensation raining down on your equipment.
   / Floor Options For Pole Barn (Not Concrete) #10
Asphalt paving if it’s in your budget. If not, I would use recycled asphalt. Compact the ground inside with a vibratory roller. If possible, put down a layer of stone. Get the recycled asphalt delivered. Place material on stone. Rake the material out as level as you can and make passes with it until nice and flat & compacted. It works better than you think and the oil in asphalt naturally helps reject those damp spots.
If you have dampness, I like asphalt paved barn floors because they stay drier than concrete.
2025 SDLANCH SDLE20 MINI EXCAVATOR (A58216)
2025 SDLANCH...
Towable Pressure Washer Trailer (A56857)
Towable Pressure...
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2017 Dodge Grand Caravan Van (A56859)
2017 Dodge Grand...
2017 Ford F-550 Crew Cab Enclosed Service Truck w/ Liftgate (A56858)
2017 Ford F-550...
