Tractor Sizing Floor boards size
   / Floor boards size
I'll Agree with that to, also found that they are a little to laid back for me. So on the cheap and easy you can see all I did was hit the Hardware store and put some 1.1/2 inch PVC. freeze plugs on the seat rests they are right at 2" perfect for me. I know it's showing again:eek:
Carey
that works for me Carey ;) my tractor came with a "ghetto" engineered bright yellow JD seat :p this color just simply wouldn't go with my attire :D
plus it sit way up to high having me looking over at the front bumper, (Not really)
but it was tall and not right for this tractor,i didfind a nice seat over at jones from another tractor (Kubota ) looked to be an after market and while i ws changing them out I went ahead and made this extention for it, did you also know that the factory bracket can be reversed and will set the seat back more than 3" just by doing this allone.... I'm going to the shop to take some pictures, be right back :)
   / Floor boards size #12
Look Hard thats what I did I'm pretty sure. Dang it's showing again:eek:
   / Floor boards size
I forgot to mention that because I raised the seat about 2" inches it put my legs closer to the steering wheels, so! then I got another steering wheel, Purchased from a local man who has all kind of tractor stuff and happen to have one from Yanmar, although i think it was from a smaller size tractor which even help more so, the steering wheel is approx 1" small in diam. and sets up approx 2" higher because the spokes of the wheel are not flat from the hub to the wheel like the old one was,it has a rise hight to it, you can see this in the picture, although I have yet to find the correct hub/center cover for it this wheel,
anyway with all the modification I have made what was originally setup for a small man now will fit a 6.1 man with large feet :D
   / Floor boards size #14
I added a step to get up on my YM240 (YM2000).
I am no taller than an average Japanese farmer so after fiddling with the seat adjustment the tractor fits me well. It feels snug but right-sized, like a fighter pilot's cockpit. But climbing off, getting over the gearshift lever, is way too complicated. When I'm wearing clumsy high rubber mud boots, 'milking boots', it is impossible to dismount without leaving mud from the right boot smeared on the front edge of the seat. I can see the attractiveness of a flat-floor tractor.
And the other tractor, the tiny YM186D, is downright dangerous. I moved the seat back so I could crouch going under low trees in the orchard. I discovered both heels caught badly which would have made an emergency jump-off impossible. My right heel was wedged under the diff lock pedal and the sole of my left heel under a 1 inch gap between the bottom of the fender and the top of the floorboard. If you move your feet forward to clear those obstacles, they are trapped under the brake pedals and the clutch pedal. I wear size 10 shoes. Summer hiking boots are ok but my giant rubber mud boots are 100% the size of the 'sweet spot' where I might lift them quickly *if* they were in exactly the right spot. If too far forward or back, I have to move them just right before lifting either one.
I seriously considered shortening the difflock lever to move that pedal back, and extending the fenders downward to eliminate the gap along their front edge. Then my shoes would slide upward smoothly at farthest-back position.
Instead I moved the seat forward again to get my weight over my feet, like with stirrups, because that feels safer than sitting way behind my feet. I think those shoe-trapping features are a significant design flaw.
Also on the YM186D, I removed the coil springs that surrounded the underseat rubber bumpers. This lowered the seating position a little. More important, this ended the seat swaying side to side which was really a nuisance when I had it adjusted back and couldn't stabilize with my feet because they were too far in front of me.
This tractor must have been designed for little kids. :D
   / Floor boards size
. :D
California-
I almost did the same kind of step,and that is a great way to ad one, although I realize by me welding a pc. from the cross member mount of the FEL bracket and then over to the frame rail I had add built for reinforcement, if ever i wanted to remove these brackets they would be permanently attached,
and i didn't want to drill a hole in the rail to bolt it on could potentially cause a weak spot because of using only 2 x 2 angle iron,
the frame rail I built to reinforce the tractor has to be slid from under the rear of the tractor all the way forward to the front and lifts up to be bolted on, then the cross mount for the loader is slit in from the side and mounted to the 4 holes of the tractor thru the built reinforcement frame. it is no doubt much stronger of a tractor now, as far as the weight it can hold, even if i were to remove the FEL assembly i would leave the frame reinforcement in place,
   / Floor boards size #16
That step in the picture is simpler than it looks. It was the control panel of some mil-surplus electronics. The edge you can't see has a lip same as the visible edge.
The step overlaps the crossmember and is wedged against it. No weld. I wrapped the far side of the step down behind the front-to-back rail then secured the step there with a hose clamp. It would be easy to remove.
   / Floor boards size #17
Re: Re-sizing a Compact tractor Floor boards size
I like the compact size of our cut tractors, although I have found 1 area where it could stand to be a bit larger.... the foot rest/floor boards area,
the Jap's must have very small feet:p and build them to their standards,
But with me have 13 EEE I found it very uncomfortable trying to step on and off of and was very limited with moving my feet about, of course for the most part I rest on the heals being ready to brake or clutch, But when being out in open Field and simply trying to relax it feels like sticking my feet in the shoe box themselves,......... so I did something about the ones on my tractor, I notice there were more space all away around especially at the rear, was 2 1/2 gap..... anyway here are a couple picture of using diamond sheet metal and cut bending it to have larger floor boards, the only thing I didn't bother to do was use the stupid little studs and springs with clips that held them down, I simply used carriage bolts nuts & washers, couldn't seethe pointin the spring deals, what! floating footboards :rolleyes:
BTW anyone with small feet need a good set of used but straight foot boards? only pay shipping :D
Large feet? How about size 15, I need to make some mods. Nice work on your mods! Thanks for adding more projects for me to do:(. I just added a permantly installed battery maintainer last night.:)
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2005 OTTAWA T2 YARD SPOTTER (A51222)
2005 OTTAWA T2...
1989 Freightliner Cabover FLA086 (A52128)
1989 Freightliner...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
MakerBot Replicator PABH65 3D Printer (A49462)
MakerBot...
