Float valves useful on top n tilt??
   / Float valves useful on top n tilt?? #1
ctgoldwing
Platinum Member
Central Connecticut
L3800HST
I have a box blade on order to work on my gravel driveway. The only other implement I'm considering right now is a back blade for lawn grading and snow removal.
I am going to install top n tilt pistons on the 3 point. In reading other threads it isn't clear to me whether there is value in valves with float function for these attachments. Is there any negative?
Intuitively it seems to me that having the blades able to float over the terrain in a big plus.
   / Float valves useful on top n tilt?? #2
Three point hitches on just about all tractors are automatically in a float mode...there is nothing holding the implement down other than its own weight...
Although I do have float positions on my rear remotes (3)...I have never found a benefit when using a box blade a rear scrape blade or a landscape rake...others have said they are of some use...some will say that it's better to have it (float) and not use it than want it and not have it...
FWIW...when grading I am constantly making minor adjustments to the hydraulic side link...
   / Float valves useful on top n tilt?? #3
I have approximately 1 mile of gravel driveway. About 3 times/yr. I use a landscape rake to pull gravel back into the drive from the sides. Following that, I use a LPGS to give it a final finish.
The float function on the right lift arm is very convenient. I set the rake at an angle to bring the gravel into the drive. I then lower the rake so that it is just about 2" above the crown. Next I put the right lift arm in float. About all that is left is to drive one mile up, turn around and do the same on the way back.
I'm very glad I have float on the lift arm.
I have not ever used float on the toplink...but I'm still learning.
   / Float valves useful on top n tilt?? #4
As /pine said... some will say better to have & not need it... I have three rear remotes with top n tilt & have not ever had the need or situation of it with my box blade, rake, or landplane... again I'm sure there are certain situations where it might be used... I just don't have the need. Oh & I'm also constantly making adjustments to my top & side links when doing grading.... (not sure how I ever graded with out TnT now that I have it)
   / Float valves useful on top n tilt?? #5
I dont see a benefit to a floating top link other than hooking up implements- being able to move the top link by hand to get the pins lined up when off the machine.
   / Float valves useful on top n tilt?? #7
I added one to my new 5090 primarily due to the fact that I got a Quickhitch. I can hook up now and not have to get out of the cab. It is also helpful when adjusting the leveling on a 3 PH disc and blades.
   / Float valves useful on top n tilt?? #8
I rarely use float with my box blade, but once in a while it's useful. I do use it when bush hogging every time.
Thanks to all for the replies.
I think it comes down to the enema definition, "it may not help, but it can't hurt"
I'm going to get the float valves.
   / Float valves useful on top n tilt?? #10
Something else to consider is a simple locking detent on one of the spools...this allows the use of something like a log splitter or hydraulic winch etc., etc...without having to use a bungee cord to hold the lever...
7046 (A50322)
7046 (A50322)
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A52472)
2013 KENWORTH T800...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A52748)
2014 Yale 3 stage...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2011 GLOBAL 130BBL VAC TRAILER (A52472)
2011 GLOBAL 130BBL...
