Float Position??
   / Float Position?? #21
View from the front of the valve....
   / Float Position?? #22
view from the right....
   / Float Position?? #23
I hope those help. As you can now see the anchor point should be to the back left and yours is to the front right.
   / Float Position?? #24
I see that. Is this something a tractornewby can fix on his own, or should tractornewby take the tractor to a tractor repair facility? I am mechanically inclined, but I've never worked on this tractor before. If, by taking the controller arm off of the controller and turning it around to be in the correct position, I am threatening serious damage to my loader controller, then I'll take it somewhere to be fixed.
Thanks for the photos.
Regards,
Tractornewby
   / Float Position?? #25
Thanks for the help, rback33. I turned my controller handle assembly around 180 degrees. In the process, I had to also rotate my 4 hydraulic hoses for lift/drop and dump/curl by 180 degrees. In other words, I had to move each hose, coming from the loader to the controller, 2 positions clockwise to make everything function as it should. Now, when I push on the controller handle, the bucket lowers, and if I keep pushing, the handle pops into a float position, but the handle won't stay in that position. I thought the handle would stay in that position but it is spring-loaded and it pops back to neutral position when I let go of the handle. I believe this controller handle must have been put together backwards from the start back in 2002, as the hydraulic hoses and connectors are all color coded to match the hose with the correct connector. If the previous owner of this tractor had taken the handle apart and put it back together incorrectly, the color coding on the hoses would not have been matched up before I rotated the handle by 180 degrees. Now the colors are not matched up but that's ok...it works properly.
Regards,
TractorNewby
2015 JOHN DEERE 60G EXCAVATOR (A51242)
2015 JOHN DEERE...
110 gal Sprayer Tank (A50514)
110 gal Sprayer...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51243)
FAE UML/SSL 150 VT...
2014 CATERPILLAR 740B OFFROAD DUMP TRUCK (A51242)
2014 CATERPILLAR...
New Valley Pioneer SCL850 Mini Skidloader (A50774)
New Valley Pioneer...
2016 FORD F-350 XL SUPER DUTY CREW CAB FLATBED (A51243)
2016 FORD F-350 XL...
