Float position on LA402 loader
   / Float position on LA402 loader #1
MarkLeininger
Platinum Member
Chicago suburban
Kubota 2710
The manual on the LA402 loader indicates that it should not be put into the float position until the bucket is resting on the ground. Is there a mechanical reason for this? I've always dropped the boom using the float position as I approach a pile.
I was also pleasantly surprised to find that curl and dump actions continue to work with the joystick in float position. Makes it really easy to feather the attack angle when doing things like scraping snow off the drive or removing snow from the horse's mud lot. The diagram for the joystick doesn't indicate that this would work.
   / Float position on LA402 loader #2
<font color="blue"> The manual on the LA402 loader indicates that it should not be put into the float position until the bucket is resting on the ground </font>
I use float the same way you do. If loader was put in to float with a full load it will drop very fast.
I believe manufactures use statements like this to avoid printing a whole book on how to use float under any condition that it might be used. /forums/images/graemlins/tongue.gif
I wish they would differentiate between what is important for safety reasons and what is important for mechanical reasons. That way I could more easily ignore all the safety advice. /forums/images/graemlins/wink.gif
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
2021 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2021 FREIGHTLINER...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
We do NOT accept credit cards as payment. (A50123)
We do NOT accept...
ELECTRIC GOLF CART (A53843)
ELECTRIC GOLF CART...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
