3-Point Hitch Float position for JD 850
/ Float position for JD 850 #1
Pforecast
Folsom, LA
JD 850
I recently purchased my first tractor. It's a mid 80s(?) 850. I don't have any manuals, so until I get them, I'll be making good use if this site. My first question is about the 3-point hitch. I'm starting to grade my property with a 5' BB. I read in one of the posts here that I should find the 'float' setting. Does the 850 have a float setting?
Thanks,
Tractor Newbie
/ Float position for JD 850 #2
Welcome to TBN!
In short, yes your 3PH has a float position since there is no downpressure, you just have to push the lever forwards. Try this, lower the 3PH all the way with the tractor running, then try to lift the arms, you'll see that you can easily since there is nothing but gravity holding them down.
Thanks Kenny. I'll give it a try later today.
Skid Steer Rotary Cutter (A65640)
Skid Steer Rotary...
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
Wilbeck 2109 12ft. Digger Disc Chisel (A65640)
Wilbeck 2109 12ft...
60in. Skid Steer Bucket (A65640)
60in. Skid Steer...
2023 Kubota Z232 (A64127)
2023 Kubota Z232...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
