3-Point Hitch Float position for JD 850
   / Float position for JD 850 #1
Pforecast
Folsom, LA
JD 850
I recently purchased my first tractor. It's a mid 80s(?) 850. I don't have any manuals, so until I get them, I'll be making good use if this site. My first question is about the 3-point hitch. I'm starting to grade my property with a 5' BB. I read in one of the posts here that I should find the 'float' setting. Does the 850 have a float setting?
Thanks,
Tractor Newbie
   / Float position for JD 850 #2
Welcome to TBN!
In short, yes your 3PH has a float position since there is no downpressure, you just have to push the lever forwards. Try this, lower the 3PH all the way with the tractor running, then try to lift the arms, you'll see that you can easily since there is nothing but gravity holding them down.
Thanks Kenny. I'll give it a try later today.
2007 Ford Fusion SE Sedan (A48082)
2007 Ford Fusion...
2007 STERLING CHEMICAL TRANSPORT TRUCK (A48992)
2007 STERLING...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A49461)
2008 24ft...
NEVER USED FECON 74in Deck Mulcher FDM74 (A50397)
NEVER USED FECON...
2016 FREIGHTLINER M2 DAY CAB (A50046)
2016 FREIGHTLINER...
2010 Keystone Cougar 5th Wheel Travel Trailer (A48082)
2010 Keystone...
