Float or Not When Using a Discbine
   / Float or Not When Using a Discbine #1
JD5210
Veteran Member
Virginia
5210 MFWD
When operating a discbine after lowering it do you put the SCV spool in float or not?
My neighbor has been having problems with at the SCV on his 6420 when using his 535 discbine. I was wondering if he puts the spool in float after lowering it, if that would take pressure off the SCV. He does go at a good clip and some of the land is a bit ruff.
   / Float or Not When Using a Discbine #2
Don't understand what the problem is.
   / Float or Not When Using a Discbine #3
I don't but I cut relatively high. I'm looking for stand longevity & hay quality sacrificing quantity. Horse people are crazy... :)
TEST BID LOT (A50774)
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2005 Sterling Acterra Tender Truck (A52128)
2005 Sterling...
2011 Ford F-150 PLATINUM (A50323)
2011 Ford F-150...
