Float not engaging
   / Float not engaging
J-J thanks for your advice and yes it is working again. I did manage to lose one ball berring, in my gravel drive way but did manage to find 3 of them. got a replacement from the hardware store $.17. The spool cap was filled with crude, and spring was pretty nasty as well as the sleeve inside. I wire brushed with the dremel, but it was pitted pretty good. I'm gonna replace everything a little later in the year, and thinking of making a gasket to keep the water out. Thanks again.:thumbsup:
   / Float not engaging #12
Expect a little sticker shock on the detent kit...100 bucks 4 years ago when I did mine. Unfortunately you cannot buy just the spool cap sleeve...That seemed to be the only part that was not reusable when I did mine. As JJ stated, put plenty of lube in there, I used all purpose lithium grease.
   / Float not engaging #13
I should have mention to use a large magnet by the spool valve/work area.
Swung by for a price check 140 now. Ouch. Well nobody said tractorins cheap. Will take a little more preventative action and stuff that piece with grease
2016 International ProStar 122 T/A Sleeper Cab Truck Tractor (A48081)
2016 International...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
2019 Ford Transit 150 Cargo Van (A48081)
2019 Ford Transit...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A51039)
2017 Ford F-550...
2025 K2223 UNUSED Double Garage Metal Shed (A50860)
2025 K2223 UNUSED...
2025 K1428 UNUSED Traffic Cones (A50860)
2025 K1428 UNUSED...
