Float function b2920 and b2763 front blade
   / Float function b2920 and b2763 front blade #1
ericher69
Veteran Member
Ontario Canada
2008 Kubota b2920
Is there a float function when using the quick hitch and front blade on a b2920? If so how do you activate this? I can lift the front wheels off the ground and it digs into the black top (yes I have skid shoes) Thanks
   / Float function b2920 and b2763 front blade #2
I don't have a quick hitch or blade on front but I've got a FEL. Float function is activated by pushing the joystick forward past a detent. You'll feel it click past the detent. Maybe your equipment is different but I thought I'd throw this info out there........
   / Float function b2920 and b2763 front blade #3
It's the same as the FEL uses, on the joystick just like coldstream wrote.
   / Float function b2920 and b2763 front blade #4
If it's like mine it needs a pretty positive push to get it in. I start with the blade about a foot off the ground, and push the lever "past" the the point of down. Hope that makes sense.
   / Float function b2920 and b2763 front blade #5
the b2920 does have a float function and as others say push the lever fwd hard enough to clear the detent. Easy to feel the "click" after you push hard enough.
same as my B2620
2013 Chevrolet Impala Sedan (A48082)
2013 Chevrolet...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
19008 (A48082)
19008 (A48082)
2020 Bell B30E Off Road Dump Truck (A50860)
2020 Bell B30E Off...
American Sanders EZ-8 Electric Floor Sander (A49461)
American Sanders...
2022 Club Car...
