Float (Detent) Not Working on L3130 Front Loader. Any Ideas??
   / Float (Detent) Not Working on L3130 Front Loader. Any Ideas?? #1
Deano
Southern Maryland
Kubota BX24
I am doing the 500 hour mainenance on a friends tractor. The float does not work on the front loader. It is part of the operation of the front loader, because when I borrowed it a couple years ago, I learned about it then. Now, it is Not working. Will not go "into" the detent.
I saw a post on here a while back...danged if I can find it now. I have tried to adjust the cables coming from the joystick, still no detent.
Any ideas? Or does anyone know the post I saw a while ago? Searched for "float" and for "detent".
   / Float (Detent) Not Working on L3130 Front Loader. Any Ideas?? #2
The biggest problem with those is normally on the valve not to say it might not be the cable but normally it is in the valve actions. Remove the cup below the raise lower spool and be careful not to loose any parts as some might have fallen out but there will be three balls riding on that spool that are supposed to be holding it in place when in float. Pack it with grease when reinstalling to reduce moisture build-up.
   / Float (Detent) Not Working on L3130 Front Loader. Any Ideas?? #3
I had this issue with my 2710, and JJ helped me out. You will need to take off the lower part of the main shaft on the control lever. There is a spring and a set of small ball bearings in there that will probably need to be replaced. I ended up taking off the whole hydraulic control valve as this piece is on the bottom of the valve and it will be difficult to put in upside down. Not very hard but it was about $165 for the replacement unit. when you put it back together pack it with grease.
   / Float (Detent) Not Working on L3130 Front Loader. Any Ideas?? #4
Thanks, now I know what I need to do to mine if lenghing the throw doesn't work. The float works fine but pops out sometimes.
   / Float (Detent) Not Working on L3130 Front Loader. Any Ideas?? #5
Not sure what your float detent looks like, but on my Kubota two spring loaded ball bearings ride over a spool that threads into the main valve. The spool had groves worn into it. I bought a new spool (expensive), but later realized that if I'd just added a thin washer under the spool it would have rotated it enough so the balls engaged a fresh surface. There is enough slop in the system that the washer thickness wouldn't have changed anything.
   / Float (Detent) Not Working on L3130 Front Loader. Any Ideas?? #6
Remove and clean the groove on the detent assembly and replace the balls if rusty.
You might be able to rotate the spool 189 degree, allowing a new surface for the detent balls to drop into.
See if you can put the spool in detent without the cables attached.
When you tighten the caps back on the detent assembly, make sure the weep/water hole is able to drain.
   / Float (Detent) Not Working on L3130 Front Loader. Any Ideas?? #7
When it happened on mine took cap off sprayed with lubricant and drilled hole in bottom of cap, no problem since then.
David Kb7uns
Thank you for all the replies... I will attempt accessing the ball bearings and checking condition. I have a parts breakdown and can see what you guys are talking about. I'll report back!
   / Float (Detent) Not Working on L3130 Front Loader. Any Ideas?? #10
I have a breakdown of the valve on question. I have circled the problem area??
Deano,
That was the problem area on my L4330. Bought a new assembly but found out when I took the old one apart that water had gotten in there and it could probably have been fixed without buying new parts.
John
American Sanders Super 7R Electric Wood Floor Edger (A49461)
American Sanders...
2014 KENWORTH T800 MIXER TRUCK (A50854)
2014 KENWORTH T800...
WEATHERGUARD TOOLBOX (A50854)
WEATHERGUARD...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2015 Kenworth T400 T/A Vactor 2100 Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
