Flipping tires for wider base
   / Flipping tires for wider base #1
Jasonpro
looking to buy
Sup Fellas, getting Kioti NX 5010. Land is a little hilly. What's y'all's opinion on flipping tires for slightly wider base? Bad for bearings? Any negatives?
   / Flipping tires for wider base #2
Did mine a few years ago. Big improvement in stability. Would have configured them wider but the tractor wouldn't have fit between the wheel wells on the trailer. Don't know about your tractor but my owners manual specifically stated not to do the front. There should be section in your manual showing different widths you can obtain.
   / Flipping tires for wider base #3
The factory would not have the option of setting them wide if it was bad for the bearings. Or rather they will have designed the axles etc to handle the widest setting.
Get the dealer to set it up like you want. They have to put the wheels on anyhow as part of dealer prep. The rear wheels are heavy especially if you have them filled.
   / Flipping tires for wider base #4
I can change the "width" on both front & rear tires on my Kubota M6040. My front tires are set at a, more or less, "neutral" setting. My rears are one click short of the very widest setting. This is all recommended by Kubota - in my Op Manual. Two tractors - 38+ years with the rears set very wide - never a problem with bearings nor anything else.
Just be very careful if/when you do any swapping. If the tires are just "air filled" they will still be heavy. If they are "fluid filled" - I would be sure somebody is there to assist you or have a professional do the work. My fluid filled rear tires weight over 1000 pound each. One slip and I could be squashed like a bug. AND I'm out here - all by myself. Closest neighbor - 4.5 miles away.
   / Flipping tires for wider base #5
You might also be able to change how wheel rim's inner dish mounts to outer rim for width adjustment, in addition to switching sides to take advantage of "offsets".
Yes, physics and geometry says bearing and axle sees more torque at wider width, but they're fine and are designed for such. Your motor will stall or wheels will spin before you overload bearing or axles.
Narrow tires are bad for bearings (along with rest of tractor) if tractor gets rolled and totaled.
Negatives are fitting into places. Like on trailers or trucks, through gates, etc..
The only negative with a mower, rear blade, etc.. not covering wheel width is if you're up against a fence, building, etc.. In fact, a narrower mower only mows zero or one trampled track instead of two.
Advantages are huge (IMHO). In my case, a few inches wider made a huge difference on center of gravity and confidence. That is, presently my tolerance limit on slopes is more psychological that physical. I chicken out before any real danger. Previously, before I widened tire width, this was not case, danger was real.
Blue Diamond 403010 3pt 4' Mower (A56469)
Blue Diamond...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A55315)
2019 Cadillac...
John Deere Miniature Decorative Truck (A55853)
John Deere...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
UNUSED PABREAK AR650 HYD AUGER (A57193)
UNUSED PABREAK...
2015 Ford F-250 Liberator 3200 1.5 Ton Crane Service Truck (A55852)
2015 Ford F-250...
