flat tire
/ flat tire #1
troweller
Kubota 3010, Farmall Cub
just got a flat tire, air and water were leaking out of the valve, what should i do?
/ flat tire #2
If it is leaking "out of the valve" check to see if the plunger is seated in the schader valve. you can either get a + tool from auto store or some metal tractor valve caps have a tool built right in.
/ flat tire #3
First thing to do is move the tractor so that the valve stem is at the top of rim, that way you wont loose all that fluid. Also, if you have a jack to use, take the weight off of the tire so it wont push anymore out. If its leaking out of the valve stem then a new valve should fix it. If its leaking around the valve steam then the tire is most likely gonna have to come off.
O, if the tire is allready sitting on the rim then dont try to drive the tractor to put stem at top as it will probably unset the tire
/ flat tire #5
If it is a stem that is 2 parts.. you can get a replacement.. sometimes the valves corode out.
soundguy
2001 Chevrolet 2500 Service Truck (A63116)
2001 Chevrolet...
2020 DRAGON ESP 150BBL ALUMINUM (A63569)
2020 DRAGON ESP...
2014 Nissan Frontier Ext Cab Pickup Truck (A61573)
2014 Nissan...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2024 JCB 35Z (A60462)
KBH Tender Trailer (A63118)
KBH Tender Trailer...
