Tires Flat Tire...Now what?
   / Flat Tire...Now what? #1
AlabamaFarmer
Minooka, Alabama
MF 1533 4WD
I've got a flat front tire on my 1533. /forums/images/graemlins/mad.gif I tried to air it up with my little compressor but the tire won't hold air. it's come off the rim. What size are the lugs? I guess I'll take it off and get it fixed.
   / Flat Tire...Now what? #2
Got a flat tire a couple weeks ago on my GC2300 (front right). Had my dealer fill both front tires with foam. It adds weight and there are no worries of flat tires again.
Cost ~$130 to do both tires. If I would have had all 4 done at the same time, the price per tire would have been less due to setup.
   / Flat Tire...Now what? #3
I have had my front tires foam fill for about one year now
and no more flats I like them
DougM
   / Flat Tire...Now what? #4
You will more than likely need to get it up off of the ground. If you have a loader it is easy, if not get a jack.
   / Flat Tire...Now what? #5
</font><font color="blue" class="small">( I've got a flat front tire on my 1533. /forums/images/graemlins/mad.gif I tried to air it up with my little compressor but the tire won't hold air. it's come off the rim. What size are the lugs? I guess I'll take it off and get it fixed. )</font>
Get the tire off the ground.
Wrap a tie down strap around it then shoot the air to it .
Beed should pop out to the rim and seal off.
   / Flat Tire...Now what? #6
The first thing to do is step
#1 jack it up so you can spin the tire freely then
#2 put some dish soap on the bead and rim lip
#3 Wrap a tie down strap around it and then
#4 shoot the air into it . like poster LBrown59 said after that it should be back on the rim .
PS the soap trick I learned from my dad who was a tire man and for best results you need a air compressor with tank not those little 12 volt air compressor . they might work but it will take a while with them along with cussing /forums/images/graemlins/grin.gif.
2014 TAKEUCHI TS70R WHEELED SKID STEER (A51242)
2014 TAKEUCHI...
CATERPILLAR 303.5E CR EXCAVATOR (A51242)
CATERPILLAR 303.5E...
Toro Sprayer Cart (A50324)
Toro Sprayer Cart...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51242)
KNOW BEFORE YOU...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH636...
